Hallo.
I’ve just acquired an Etherwave Plus and this evening I removed the top cover.
There is a black wire running from a connector in the middle of the switch panel - where should it be connected to? At the moment it’s just laying loose!
Etherwave Plus loose wire
Posted: 2/17/2021 7:47:45 PM
Sometimes the black wire that is terminated with a solder lug is one that should be screwed to the aluminum foil patch on the pitch side of the main board. If you see a screw hole in the corner of the patch with no wire then this is probably it. It's a tuning thing, and sometimes a user will disconnect it. Mine is disconnected.
If it's a different black wire, try posting a picture.
