Open Theremin V4 with MIDI
Posted: 3/4/2022 11:16:40 AM
Mr_Dham
This is just to inform you that Open Theremin V4 with MIDI is in Beta state and I am considering delivering official V1.0 in a few days.
I recently had opportunity to test the Open Theremin V4 (very nice !) and could finalize my implementation of the MIDI feature.
I merged recent evolutions from Thierry.
Don't hesitate to have a look at the Github repository.
Any feedback is welcome :-)
Posted: 3/9/2022 12:19:28 PM
Buggins
V4, but still uses slow ancient 8-bit MCU.
Posted: 3/9/2022 6:42:09 PM
Mr_Dham
Yes, it is basically a merge of OTv3 shield and arduino uno in a single board. This let some I/O port on the MCU to manage a complete set of CV/Gate outputs. And now you can add a MIDI interface to V4.
Of course, it is an entry level instrument, but for the price you have have a prety good linear theremin that can control some analog or digital synths in an Euro-rack form factor. It opens the field for extensions... (e.g. Open Theremin + Oscillator module + filter module)
Posted: 3/11/2022 9:16:02 PM
Mr_Dham
It is in V1.0 !
Just the begining of the story and a base for improvement...
Posted: 6/25/2024 12:23:09 PM
Mr_Dham
Just a few words to say that I removed all calculation in float 32 bits from my MIDI code and replaced it by proper fixed point mathematics.
If you want to have a look.
Thanks to Crisbei and Dewster for help and encouragement
Posted: 7/7/2024 5:34:59 PM
Mr_Dham
And I did the same change for Open Theremin V3 with MIDI.
Posted: 3/14/2025 3:23:21 PM
Doug Forbes
Has anyone wired a V3 board to a NANO instead of an UNO and run V4 firmware ?
Posted: 3/15/2025 10:30:13 AM
Mr_Dham
Not so much aware about arduino nano and would need to consider how you bridged your V3 shield to it but...
V3 and V4 have different connection to I/O pins. These hardware differences are reflected in the firmware.
Then V4 firmware won't work on V3 hardware and the opposit is also true.
But I don't catch the point of doing so... V3 and V4 firmware are both up to date at an equivalent level.
Posted: 3/15/2025 2:39:46 PM
Doug Forbes
I have done it and it works. Except for the DAC for the CV's the hardware is similar enough. The problem is that there is "jitter" in both the volume and pitch and I am wondering if it is a compatibility issue. It seems that the 3.3v line is randomly being loaded down. Maybe one of the IC's is loading the power down. Tough to troubleshoot SMT especially since the Theremin works as it should except for the jitter.
