I'm an electrical engineering whos currently trying to design and construct their own theremin. As part of my coursework, I have worked a lot with amplifiers, but this is my first time building an oscillator of any kind. I recently designed this thing:
Which is based off of a negative impedance generator. From my calculations (and my very limited knowledge of oscillators), I managed to calculate that the resistance looking out of from the base of Q3 will be negative, which I think means that if I connected an LC tank to the same net as the base of Q3, then the circuit would refresh the energy lost by the LC tank will thus oscillate.
Unfortunately, after simulating the circuit with a simple LC tank connected to ground, this doesn't seem to be the case. The circuit will either flatline at a certain voltage, or there will be a period of oscillation that gets dampened out after the first 100us.
I'm sure I'm missing something basic, but can someone help to point it out? Is my perspective of what makes a system oscillate wrong?
