Schielenkrahe gave similar advice in the Aerial Fingering forum and I found his advice to be extremely valuable.
Mr. SchielenKRahe is a gifted precision Thereminist and his performances are really quite free-flowing.
While exercises such as the Clara Rockmore method emphasize hitting the notes Schielenkrahe's exercise will help you learn the manner in which you hit the notes. The space between the notes has as much to do with the performance as the notes themselves. The other benefit is that this excercise may open doors for you -- you may find yourself playing material on the Theremin that you would have thought impossible.
Just as vibrato and dynamics influence the mood of the music, so does the movement from note to note. A rapid movement gives an "urgency" to music, a relaxed gliss gives a sense of calm, a slow glissando can be a special effect or it can be "molto expressivo" depending on the context.
Anyway, this is somewhat off the topic of "jitters" however wanted to mention that I have found value in these methods.
