Forgive me for asking. I’ve read many pages about arial fingering here at theremin world.
I’ve been reading about and watching videos of arial fingering for quite awhile before
I stated practicing the theremin. As I have never seen anyone play the theremin
face to face I don’t know how much of this is confused by camera angles.
Clara Rockmore seem to be holding fingers vertical. Small finger on bottom toward ground, index finger touching thumb on top, toward sky,
and then extending knuckles towards and away from pitch antenna. (Never really fully extending the small finger towards the pitch antenna.)
Mr. Pringle seems to use a modified version of Clara’s method. Pamelia Kurstin also.
Although also called arial fingering, Lydia Kavian seems to be holding fingers inline horizontally. (Small finger closer to antenna, index finger touching thumb closer to her body.)
There seems to be more vertical movement of the knuckles toward the sky, with a horizontal stretching for the hand, and especially extending the small finger,
finger tips pointing initially towards ground,, not as much knuckle movement towards antenna. (Knuckles moving more towards sky.)
This method seems that knuckles movement would change the pitch in a smaller way.
(Are there any other videos of this style of playing by other theremin players?)
Carolina Eyck seems to be between the above two. Fingers almost extending at a 45 degree angle. (No real knuckle sliding towards pitch antenna as in Rockmore arial finger.)
Any comments about pros/cons of what seems to be different styles of “arial fingering”.
(Or am I just hallucinating?)
I’m so picky about this because I had to learn the “correct” way of holding a violin and bow after 4 months of study from my first teacher, a new teacher to violin.
When I got a philharmonic section leader as a teacher it was torturous to relearn, I almost quit.
Theremin is difficult enough, adding a start over is not something I want to even think about.
Thanks,
Thanks,
