Parsa. I'm just starting careful work and planning on a Theremax kit, and I have plans for later adding a Lev Antenna. I'm gonna use clear pvc pipe for the vertical section containing the spring, with a cap on top, a 90 degree angle on the bottom and a short section of pipe horziontally through the right sized hole in the wooden cabinet, a snug fit. The outside diameter of the pipe I have is in between 13/16" and 7/8" 27/32"... Hmmmm might drill a 13/16" hole with a speedbore bit, then make it a little bigger with a half round rasp or sandpaper,,,?
It might seem that the spring rated at 9/16" diameter shouldn't fit into a 1/2" inside diameter pipe, but it does! The dimensions are all detached from so called reality, like wood, a "two by four" is neither 2 nor four inches no matter how you measure it.
The rings at each end of the spring might need a little squeezing to fit down the pipe. Below I will post the details of my plan.
