Hi Chris,
using an inductor with higher inductance is (IMHO) not the best option in the EM- and Etherwave design because going too low with the oscillators' frequencies may cause too high resonance current problems with the antenna linearization coils.
That's why I suggest doing the same as Moog does in newer circuit variants: Replacing the variable 100uH inductor by a fixed 47uH inductor in series with a variable 47uH inductor like the EZ-1017.
Another alternative is using the Coilcraft SLOT10-5 which has also 47uH (always in series with a fixed 47uH inductor), but since the DC resistance is different (which is crucial for these differential pair oscillators), some resistors in the surrounding circuitry must also be replaced in order to stabilize the oscillators' working points:
R2, R6 and R16: 1.5k instead of 2.2k
R15, R19: 330 instead of 470
