What he said....(Thierry and Peter)
This topic came up a month or so ago elsewhere, and this is what I wrote to one person who was confused by these issues.
"Loudspeakers can be used without a baffle, but they will quickly lose power at lower frequencies from cancellation. If you do not need to rattle the windows, this is not always a problem.
The simple pole-mounted diamond speaker is an "open baffle". Some audiophiles prefer open baffle loudspeakers for their clarity (uncolored by an enclosure) and "presence". The size of the baffle will determine at what frequency cancellation will become an issue. The speakers (drivers) used must have a higher self-dampening quality (electrical and mechanical 'Q' factor).
From the diagram someone provided once, the diamond speakers produced by Floyd Engles apparently had some sort of enclosure around the back of the speaker. This would allow better bass response with a smaller baffle. Some sound reinforcement companies, such as Atlas Sound, do sell "back boxes" for speakers up to 12". These are for (acoustical) support and dampening of ceiling and wall-mounted speakers.
Since they do not play down to the lowest frequencies, many guitar amps have an open-backed enclosure, which is simply a folded open baffle. This is also one way to get better bass response for an open-backed diamond speaker.
Acoustic suspension (closed) speaker cabinets are basically an "infinite baffle". They also provide some mechanical dampening of the speaker cone to help keep the sound "tight". They often contain some sound absorbing material as well. Their size and volume must be "tuned" to the speakers used and, for large speakers, the cabinet can become quite large. They can support very deep bass, but are less efficient and require more power.
The bass reflex (ported) enclosure is basically an acoustic suspension (infinite baffle) cabinet with a hole in it. The benefit is they are more efficient (require less power) and the cabinet is generally smaller. The port is tuned to the bass driver used to extend bass response, but at some point the "hole" will cause the cabinet to become unloaded and the bass response will fall off drastically. For large speakers, this is generally such a low frequency as to be a non issue if properly designed."
Designing speaker enclosures is both an art and a science, but this is far more important for speakers designed to reproduce all instruments at all frequencies. (Music reproduction rather than an instrument speaker.)
It will also add considerably to the size and weight of your speaker. This is something to consider when you're trying to balance it on the top of a tall pole.
A simple open baffle makes things much easier as well as imparting a more "airy" quality. A simple open baffle of 24 inches square (61cm) should give you good support to the lower viola/tenor range.
Achieving full support to the bottom of the cello range will take a baffle twice as large; about 50 inches square (122cm). In this case, an enclosed back (or open box) would probably be desirable. Then you get back to the size/weight issues.
