[i]"The Q can make anything work simply by changing the universal constants and the laws of thermodynamics" - StarPort[/i]
LOL! ;-)
In fact, Q can be easily understood without deep understanding of "the universal constants and the laws of thermodynamics".. "The Q" should never be spoken about.. The "Quality Factor" can be talked about, and is Q, but not "The Q" (?
Enough nonsense!
Q is simply and directly a function of the effective series resistance of the inductor - In plain english, what this means is that if the resistance of the wire used to wind the coil is high, Q will be low -
Thicker wire has lower resistance than thin wire - gold plated ECW has even lower resistance, pure gold is best! ;-)
If the wire used is as specified, and the coil is wound as specified, Q should not be a problem.. Unless the wire is thinner (>R =
My limited expierience leads me to believe that the inductance value (in combination with antenna capacitance - ie - they must be carefully matched to achieve resonance close to the oscillator frequency) is by far the most critical factor in achieving linearity.. and that the next most important factor is the (inter-winding) capacitance, and the physical positioning of the coil with respect to other 'grounds'..
Adding small ferrite 'tuning' inductors does reduce over-all Q (these inductors tend to have quite low Q values, and quite high capacitance) but I have found this had no noticable effect.. It was quite interesting when looking at the insides of the Tvox (which has good linearity) to see that quite a small ferrite inductor is used for equalization..
Tapping the coil to allow selection of the optimum inductance, has no disadvantages.. it does not decrease Q (particularly if you 'tinned' the taps so that the extra wire did not add extra resistance.. but this is being absurdly pedantic!) does not increase capacitance, and allows the option of changing the oscillator frequency if one ever needs to in future, and selecting a different 'tap' to retain optimum linearity.... After having hand wound many coils (I have now built myself a winder) I learned that putting a LOT of taps was well worth the extra effort.
Big coils look great - and when accompanied by glowing tubes produce wonderful instruments..
But I do not think there is any substantial advantage in big coils.. Or, put it this way.. You will get better linearity from a low Q ferrite inductor which has the absolutely right inductance value, than you will from a large coil which is slightly out of tune.
I have never built a tube Theremin, and all my observations are based on solid-state... I cannot see how this could make any difference to the above - But, with Theremins... Well, sometimes I think maybe "the Q" uses them as a means of transportation or something....
