Basics of EW-Pro.. #2 (and related issues)
Posted: 7/1/2010 10:09:53 AM
[i]"It occurs to me that one could pass any simply pitched audio signal through a comparator and use it as data for the "second theremin", along with an envelope follower to track the volume of the signal. Kind of like the opposite of a vocoder." - Gordon[/i]
In theory, yes.. In practice, perhaps..
I am saying (have said) way too much already.. I was working on a heterodyning VCO.. The basic scheme I started with was taking control of the VFO and simply changing its frequency from the CV..
My problem was stability and linearity - the exponentiation required for 1V/8ve combined with the non-linearities of the HF oscillator combined with the tiny % required change in VFO frequency made the design an absolute monster, and the prototype even worse!
Then I got the PLL idea - I thought Eureka!! Just make a standard exponential VCO, feed its output to a phase comparator, use the output from the phase comparator to control the frequency of the VFO in the heterodyning Theremin circuit, Square the output from the analogue heterodyning mixer (actually, I had a seperate D-Latch based digital difference frq detector) and feed this back to the phase comparator, and use the analogue output from the mixer as the audio output..
With this system, one has an entirely analogue heterodyning Theremin - with oscillator interactions changing the waveform, and with the degree of oscillator coupling being fully adjustable - it will never lock up, because the PLL wont allow it to! - The ultimate analogue Theremin!
I also thought about its use with other audio signals as control inputs..
So damn simple - So bl***y obvious..
Alas, low (below about 200Hz) signals screw the system up.. In order to cater for these the phase comparator output needs to be too long a time constant on its filter / integrator.. A long TC slugs the response at higher frequencies - one is limited to about 3 octaves, and performance is better at the HF end..
I have found a fix.. It is not simple, but it is simple when applied to Theremins and specially tailored VCO's.
I have not yet found a way to get the PLL to stay stable for any 'normal' audio input below 200Hz.. and I am not spending time on this at present - I have what I need for the task in hand - I believe that the physics, when related to normal audio frequencies, prevents reliable operation at low frequencies for the same reason that standard pitch to voltage converters fail at low frequencies - It takes 50ms for a single cycle of a 20Hz waveform to be seen, and 50ms is an extremely long time! .. It takes 5ms for a single cycle of 200Hz to be seen - even 5ms is a long time - but it is approaching usable.. In fact, more than one cycle is really required - so 200Hz can be locked in about 10ms.
But, as you said earlier - PLLs occupy volumes of heavy maths etc - When one really starts getting into PLL's, the maths and theory becomes extremely weighty - too weighty for me!
And its not just as simple as multiplying the input frequency by 10 using a PLL! ;-) .. Because the source data for such a PLL would still only update (at maximum) in one cycle..
One can make a fun tracker simply using a PLL (4046) with its VCO tied back to its input, or via a couple of dividers.. I say "fun" because its behaviour at low frequency becomes almost a random tone generator, loosely focussed on the input pitch.. I made quite a few of these back in the early '70s and they sold well - But back then, even Xtal radios using an OA91 sold well ;-helped to pay for all the wonderful electronic junk you could buy - everything having tubes!)
And that is all I am going to say on this subject.. I have already said more than I should, and I know that if the right person read this and spent some time thinking it over and prototyping / experimenting, they will find out the 'fixes' I have worked out.. or come up with different solutions.
Posted: 7/1/2010 3:47:01 PM
kkissinger
A related topic came up back in 2005 (you can scroll down to see my analysis and suggested correction to the Epro's block diagram:
http://www.thereminworld.com/forum.asp?cmd=p&T=1394&F=808
Ah... the topic of Lunettas surfaced.
The 2010 Regional Electro-music festival
http://www.kevinkissinger.com/kcregionalem2010.shtml
will include a seminar on Lunetta History, Construction, and Sounds at 12 noon CDT Saturday, July 24 which will be streamed live on the internet.
The presenters are Damon Mar who will demo his latest Lunettas and Howard Moscovitz who has known Stanley Lunetta for many years. (Stanley Lunetta created the kind of improvised noise-making circuits that are now known by the diy community as "Lunettas".)
Incidentally, the International Electro-music festival next September, http://electro-music.com/article.php?t=41222 will include a hands-on Lunetta-building seminar. For a small fee (around $50) each participant is provided a breadboard, chips, and components to build their own Lunetta. Afterward, the entire group will interconnect their Lunettas and present a Lunetta set. And of course, the participants get to keep the materials that they purchased for the seminar.
My 13-year-old son is going to do this seminar and I hope that I can, too (depends on the schedule -- I tend to get pretty busy at the festivals).
Posted: 7/1/2010 5:44:32 PM
Thank you Kevin!
Your comments / analysis in http://www.thereminworld.com/forum.asp?cmd=p&T=1394&F=808] are an extremely good reference for this thread.
That "2010 Regional Electro-music festival" looks like great fun - Oh.. I wish I could attend.. Perhaps next year -
Posted: 7/1/2010 6:17:19 PM
Kevin - what a great event you have organised. The participants are going to have so much fun. (And you are going to be so busy and have a load of fun too.)
Posted: 7/1/2010 9:22:01 PM
teslatheremin
Fred,
You seem to be giving away 'Your Store', here!
Please, stop.
Or, you will face fierce competition.
Bl**dy,Good Luck!
teslatheremin
Posted: 7/1/2010 9:49:44 PM
[i]Fred,
Please, stop.
Bl**dy,Good Luck!
[/i]" - teslatheremin
Thanks TT! - But I almost am past caring! I do not actually believe I can make a living from high end Theremins, let alone any real profit.. In reality, my situation makes actually putting product into production nearly impossible.. I dont have the funds for even the minimum production run which would produce savings as a result of scale (in fact, I dont have funds to even finish off the remaining SBC Theremins which only require some Maplin speakers.. LOL) - and without cutting costs, the Theremins will be too expensive to sell..
I dont have the space to build the units myself (the space taken for assembly of the 16 Theremins for the SBC caused major domestic mayhem) and my only realistic option is to have a batch of at least 100 Theremins assembled in China, if I want to come in at close to the Epro launch price.. And I would still need to check, calibrate and store these Theremins until they are sold... But all that is achedemica anyway - I could never raise the money to pay for the first batch - probably at least £30k.
So, If someone else beats me - so be it.
I am a designer / developer, not a manufacturer - And my business plans are in tatters.. And even when I do build and sell Theremins, I lose money..
So let others build Theremins based on my ideas - its ok.. Be nice if I got some credit, and even nicer if I or www.streetkidsrescue.org got some money - but hey - Im becoming a realist!
(there is one sector of the Theremin market where I might be able to make some money - down at the low end.. EW Standard and Sub-EW Standard price range.. Since the SBC show, this is the sector that almost every request has been for.. The lower manufacturing costs makes it possible to order larger quantities and therebye reduce prices further.. But this sector is already well catered for by Moog, Burns and others - I really dont want to clutter it even more)
