"(Next time I'll try plugging the iBook into the headphone socket of my amp instead - see how well that works - just this moment thought of that.)"
Are you thinking of reamping the signal or preamping the signal? To be more specific: are you planning to rerecord the track with the amp in the chain, or send the prerecorded track out to the amp and micing the amp?
"1. I'm concentrating so much on the pitch I'm forgetting about volume. The piece lacks expression. "
I agree, but your getting really good with the pitch hand. Bravo!
"2. In the second half I'm stopping the vibrato just before the end of a phrase, so the pitch goes a bit wonky."
I didn't really notice. I'll need to listen again.
"3. I rushed the very last note. It should have been a bit longer and faded out gradually. Actually I rushed the whole thing a bit."
I have to disagree with you here. I liked the quick ending. It leant a bit of immediacy to the piece. As if to say, "I'm finished, so there."
My only complaint is that this piece lacks the density that your other works have. It's a little naked. That could work, though, once it's put up against your other pieces in an album format. I would work on the expressiveness a bit and see if you can get the piece to say more.
Hope this helps.
Hope this helps.
