Yup, horrendous, but you failed to mention the immense comedic value, Charlie D. Perhaps the presence of Alex (14) who shares much of my sense of humour altered the equation, but that was hilarious. Particularly since, having set up my template it was pretty easy to sample other stuff. My rendition of the Worm Song (http://www.theboys.co.uk/lwormsong.htm) was er, ... sound of file hitting the trash can and a few megabytes of data ascending to hexadecimal heaven
Actually, horrendous is an imprecise description. OK, so with the theremin we got many mumbling mice, no doubt about that, but mice on mescaline would be about right. and not especially harmonious, shall we say.
This was more nightmare than sweet dream. But it would sustain a melody line of sorts. So one for when I am tempted to go all out for a nightmare soundscape. And I have to admit it sounds like a very tempting challenge. See if I can scare myself!
So how to proceed having not immediately achieved my goal? Apparently "apace" is the answer. I plunged ahead and simplified my convoluted scheme, losing the fourth voice and trying just a straight-forward equal temperament 3 note chord. I found a nice one on the keyboard with the right sort of mood. This worked a little better. Especially when I superimposed the three voices and reduced the volume of the two modified voices. This had more harmony. It's not there yet, but it's a step in the right direction. And it gives a broad non-italic stroke in my little system of classification. But - big downside - not realtime - this is post-processing with progress bars, so harder to learn what effects different gestures and different chords have on the mood it evokes.
Or perhaps, it occurred to me, I could approach it from a different angle and consider harmonics. In effect what I was doing was adding higher frequency copies, so perhaps I should revisit the waveform. So I recorded a couple of slow traversals and looked at them up close. This was after only a minute or so's warm-up time - I'm going to try again tomorrow but let it warm up properly. Also found a real-time spectrum viewer in Amadeus. This time I found I could read a lot more from it. I see what you mean about the bass tones Charlie D - that's pretty square-wavey - real nasty shark's tooth of a spectrum, and up in the high range is a bit triangular and sharp, the mid-tones gave nice sinusoidal curves, but not sine waves, as the spectrum revealed a nice compact little diamond of frequencies with a couple of evenly spaced - on a logarithmic scale, so in a fixed ratio to one another - smaller copies above them with the distance varying smoothly with pitch. Fascinating. Just what I was doing with the pitch shifted voices. (fx: Raises a Vulcan eyebrow.) Also, I spotted some heterodyne birdies! Wow! I'm a heterodyne bird-spotter. Where's my thermos flask?
Seriously, this has helped my ear, no doubt of it. I have a much clearer idea of what I am listening to. Also I found out that I have been recording too loud - apparently it's not enough to just avoid red-lining the onscreen meter, I should record at lower levels and have more confidence in Amadeus's ability to remove noise and normalize my recording. Also I should not have given up on the mike on my headset so soon, it was doing the right thing in insisting on giving me lower levels than I thought I needed.
So, some good outcomes. An excellent failure. :-)
Gordon
Gordon
