read about 2/3rd the way down to get to the point...
QUOTE
The cabinet of your Etherwave Theremin is made of cabinet grade hardwood that looks good with virtually any wood finish that you care to apply. Here are some suggestions:
*it is extremely important that the finish you choose be non-conductive.
The pigment in many black paints and stains is composed of carbon, which conducts electricity. A finish of this sort will load the Etherwave’s antennas, thereby disabling the instrument. If you want to paint your cabinet black, it’s a good idea to select a lacquer or varnish with a label that lists the pigments materials. The list of ingredients should NOT include carbon or graphite.
END QUOTE.
Now I need the help of someone smarter than me.
Although I lettered in algebra two years in a row, I still flunked chemistry two years in a row, so it’s a very weak topic for me.
The Moog instructions say not to use anything with carbon or graphite.
But every varnish or shellac finish has the warning, “CAUTION! CONTAINS ALIPHATIC HYDROCARBONS”
I already have one coat of the HELMSMAN SPAR URETHANE on the case and plan on 3 or 4 more coats.
Should I just burn the case in a fire and start over?
or will i be ok with this stuff?
QUOTE
END QUOTE.
