Where on planet earth are you located?
Thank you for the sound byte. Use Audacity and compare your wave form to my EWS wave and you will see your wave form peaks are squared off indicating you are over-driving the input to your sound card. You also have a weak physical connection in the power or audio path.
RS Theremin EWS <=Grandson thinks start of this sounds like Spielberg’s “War of the Worlds.”
zigmenthotep EWS
I would “not” expect this clipping through your stereo line-in but a ground hum may be what you heard. I have had very good results with amplified computer speaks with a sub-woofer; they better equalize the high and low frequencies.
All later model EWS use the three prong power plug, I am not sure about the very early models or what you have. Earth ground is important in the wave shape of your sound; you do have a three prong plug? My guess is your EWS is probably working fine, just over-driving or too hot for the amp input.
There is a gadget around here we can buy to add two lower octaves to our sound and we can parade around like a heard of elephants, it is very exciting. The EtherWave Standard is a good starter theremin when you don’t know what you will be missing. About a 1000 of the advanced Thereminist abandoned the EWS and went for the EtherWave Pro for two apparent reasons and their ability to play raised exponentially, “this is something kept secret”.
Secret? I just let the cat out of the bag; no one else will respond and help you now.
