"Also quite interesting. You seem to be using the winding to optionally reduce sensitivity (quite clever) but have you noticed if this arrangement can increase it over the standard LC tank & L EQ? I'm really interested in increasing sensitivity. If I read you right, if the separate winding has the same number of turns as the tank L you get similar sensitivity as just connecting the EQ | antenna to the tank winding like usual?" - Dewster
Actually, I am using the extra windings to increase sensitivity - The RCA (well, I am now using the Clara-Min topology) has quite low sensitivity - but the principle could be used for either increasing or decreasing sensitivity I think ..
I think it works like this..
The antenna tuned circuit is operating in its inductive zone - change in antenna capacitance 'transforms' into a changing inductance which is in parallel with the tank coil / transformer.
The variation in this "virtual" inductance, as you know, is a complex function based on the resonant frerquency of the antenna LC and the oscillator frequency driving this - But for a given change in capacitance over a given frequency span, the function (and therefore the variation in XL) is constant..
Now, if we take this varying "virtual" inductance, and strap it across a 160uH tank coil, we get a resultant change in the oscillators frequency (and the complex relationship caused because the change in oscillator frequency changes the value of the "virtual" inductance) .. If we strap this "virtual" inductance across 320uH (a tapping further up the coil) the proportional effect of the virtual inductance on the tank transformer is increased, and sensitivity is therefore increased.
I have yet to work out exactly what is happenning - its not a simple relationship, as in, the number of extra turns (or increased coil inductance) to increased sensitivity is not what one gets from simple inductances - the coupling being to both windings seems to be introducing anomalies.. I have now reverted back to having the extended windings connected to the original antenna connection point (the Anode in the case of the Clara-Min, and the Grid in the case of the RCA - I am using the Clara-Min topology now) rather than having a seperate winding which is grounded at one end, and this seems to be more stable / predictable.
But I will say no more until I am sure that its doing what I believe it is, that its repeatable, and I have checked my theoretical hypotheses against the test data and can be reasonably sure I am not talking BS ;-)
Thanks! I tried your suggestion today, lots of splatter on the scope now and then (infinite persistence pays off) but I'll have to compare it to a smaller coil to know how bad it is.
If you trigger the 'scope from the "noise detector" you should be able to confirm whether this is whats causing the phase shift errors ?
"What I don't get is why the Bournes | Miller EQ inductors don't seem to overly bother analog Theremins - hanging a long string of them off the tank seems to be asking for it."
Analogue is a lot less fussy than digital - Just look at the filter on the mixer output - one can have 100us of highly distorted HF signals ariving at the mixer and being processed, and hardly even notice a distortion on one cycle of the audio output waveform... Try getting a PLL to stay stable when it loses its signals for 100us, or a digital counting system to give accurate output when signals go erratic and its a whole different ball game! .. With analogue heterodyning, there is an intrinsic "noise filter" or "averager" at its heart - individual HF waveforms have little or no impact on the audio output - one could probably lose 10% of all the "valid" HF and throw in 10% of random stuff, and still end up with audio that was not too objectionable.
Not that I would advise anyone to be cavalier with their analogue HF signals ;-) - But compared to the care required to keep a digital system happy, Analogue is, IMO, Easy! (I have certainly been bitten by the rabid digital theremin "dog" - And its fear as much as anything else which keeps me from returning to his garden! ;-)
Oh, just FYI - I am using air core for my transformer - an EFD-25/13/9 former without the ferrite - had been using plastic sewing machine bobbins, but its a pain to mess with flying leads.. these Epcos EFD parts (PN: B66422W1010D1) have 10 pins are £1 and 180 turns on the first 2 layers gives 200uH, then 150 turns on the next 1.5 layers gives 160uH .. I strap a tunable IFT inductor across the first layer (between grid and ground) to trim the total series inductance, the 2nd layer is between "Anode" and +V, and the anode (normal antenna circuit connection point on the Clara-min) is taken to my additional windings.. I switch the antenna connection between the Anode (lowest sensitivity) to tappings from the 'extended' winding (the more turns, the greater the sensitivity) - Phase is obviously important.. If one has the 'phase dot' at the +V and the other main windings phase dot at the grid, then the extended winding continues in the same direction from the anode 'downwards' and tappings are taken from this.
