"but you couldn't play it like the Ondes Martenot ie sitting at a keyboard...or could you?" - IJ
Oh yes, you could! - Its simply about how the antenna is shaped.. The drawings I posted show total capacitance for the arm + hand, and the antenna shape would need to account for this.. But one could design the antenna shape to give a linear response for just a moving hand - effectively the angle and curve of the antenna would need to be steeper.
Remember, there are two primary 'variables' when it comes to capacitance between two conductors - one is area, the other is distance. My diagrams show the area of the arm being included - But if one makes the area constant (as in, the overlap between the hand and the antenna) one can play with the distance alone - in fact, this should be easier.
I simply knocked this idea together as a quick and easily implemented solution to my possible problem. It is possible to make a much more accurate 'keyboard' arrangement by using more than one shaped "antenna" and looking at the capacitive difference between these to determine the hands position - This is what I did on my "Epsilon" pitch antenna.. But it is much more complex than what I have prsented here.
"That is if the antenna is a thin metal strip the capacitive sensing would be directional therefore you may be able to sit next to your box and slide you hand side to side over the keyboard" - IJ
For this sort of construction, I found that self adhesive aluminium tape is a great material to work with, one can stick this onto flexible plastic sheet (in fact, I once used a 1m plastic rule which was perfect, as it flexed easily and was easy to bend to an exponential shape).. Most of my experiments (and prototype "products") however did not use bent antenna - I shaped the antenna by cutting the tape into the required shape so that it could be stuck onto a flat surface -
On Epsilon there were 4 antenna formed with a quite complex pattern (to distribute the sensing evenly) etched onto PCB. The thinness of the tape / PCB means that you dont have to worry overmuch about horizontally induced capacitance - although, on the scheme I drew here, this will probably need to be taken into account if one does a "keyboard" version, as the players body will be sensed by the antenna due to the angular capacitive components - It may not work well (or at all! ;-)
