I found this crude test oscillator I built years ago to test SRF of inductors - results are only "ball park" .. dont use this if accurate measurement is required.
This is based on the EM theremin design by Bob Moog - It is a wonderfully reliable oscillator, and clipping an inductor between +Vout and TST one will usually get oscillations at aproximately the SRF of the inductor.. I think it worked at least down to about 30kHz and up to about 2MHz if I remember correctly
I put the transistors in sockets, as it is possible to blow them up if one connects something stupid - I also put sockets to allow a capacitor to be connected across the inductor.
A simple, basic but useful piece of kit for theremin developers... May also be useful for those laying out EM theremin circuits (plenty of space near the test connectors to put a tunable inductor, fixed inductor and capacitor, without any top-side links - just move the ground track).
Built on 0.1" pad board.
Pads G1 and G2 are ground, VP1 is STABLE +12V, VN1 is STABLE -12V, Out is to 'scope / frequency counter, VP2 is +V supply to inductor, TST is to other side of inductor. Note that the TST lead is an "antenna" - it needs to be short.. The OUT signal will be low level unless into a high-Z input - the 100k is in series to reduce the effect of the measuring instrument, but this isnt ideal.
Layouts viewed from component side (top).
