"So, bottom line, is there any magic in the Lev oscillator? I just see it as a split coil design, done more for active component (tube) biasing reasons than anything else, but maybe I'm missing something critical." - Dewster.
I havent done the maths, and I haven yet been able to modify your spreadsheet, and I havent built a Lev oscillator / antenna resonator and run tests on its linearity - so this is "guessing" or "hunch" more than anything else - probably...
The operation of the antenna linearising, as I understand it, is that effectively the antenna resomator behaves like an "variable" inductor in series with the tank inductor.
In parallel tanks, this "virtual inductance" sits across the entire tank inductance (in fact, across the entire tank resonator) - With the Lev oscillator, it is only imposed across one half of the tank inductance ..
I see several possible implications of this - but these are probably unfounded hunches.. 1.) The effect of the antenna resonator will be reduced in "global" terms - as in, loading will be reduced on the primary feedback mechanism, as there is no "virtual inductance" across this. 2.) Although "reduced" (because it is only across 1/2 the total inductance), this "virtual inductance" is likely to have a modified behaviour because it is across an inductance which is coupled in a complex way to its "other half" (the split inductances actually combine magnetically to form a "single" inductance, but this is split with the series tank capacitor forming the series resonant tank circuit).
I am out of my depth a bit in understanding the complex behaviour of this network, but we do know a few things about the Lev theremins.. And amongst the "facts" are that:
A) they are reputed to have exceptional linearity - linearity which SHOULD be common place in all theremins if there is nothing "magic" going on, but which isnt commonplace..
B) they have a smaller range (fewer octaves - less "sensitivity") than most more recent theremins.. But this alone is not the reason for the improved linearity - One can build a parallel tank based theremin with reduced sensitivity, but gain no linearity advantage - you generally just get fewer octaves with little or no improvement in linearity.
To me, there was no basis for the improved linearity over modern designs until the "mysteries" of the Lev oscillator were "revealed" - Now there is a possible reason - not saying it is the reason - But it certainly looks more likely than the other "reasons" we have heard like tube behaviour or large coils or "non capacitive" sensing mechanisms or mysterious antennas!
C) Almost every theremin designed / built other than Lev's originals, use parallel tank oscillators, and it has been believed (since the 30's !?) that this was Lev's topology - even to the level that schematics drawn and analysis of the Lev theremins have had wrong inductance values because these were based on calculating with the assumption of a parallel tank circuit.. All theremins (other than direct physical copies of Lev's) since the '30s have probably been built "wrongly" on "wrong" assumptions!.. Or if not "wrongly" at least "simplistically" - because I think we will find that we completely missed the brilliance of Levs "Front End" and only picked up on the crudest fragments of his ideas.
Is there magic ? Well, I would bet my last remaining pennies that a correctly implemented Lev oscillator with a correctly implemented antenna resonance circuit will be a lot more linear than any "standard" theremin with paralell tank resonator and optimally implemented antenna resonator, and that the Lev Oscillator will be more stable, particularly when coming under synchronisation of another oscillator.
Is there any other magic? wave-shapes / blocking actions etc? - I dont think so.. Except perhaps for its possible synchronous behaviour / stability in a theremin design when VFO and Ref oscillators are loosly coupled.. But even here I could be wrong - Lev was, undoubtably (IMO) a greater genius than has been realized - I think his "Great Seal" probably demonstrated how subtle and elegant his thinking was - an entirely passive bug built with effectively a capacitive microphone and external excitation provided by the remote reciever - and think about the date that was implemented! - I think we should be on the lookout for some other hidden tricks! ;-)
