"I suspect these will come in handy" - w0ttm
LOL ! - You dug into your junk box, and found a pair of 27's, and some 24's ? .. Hell - Im starting to think there may be metaphysical events occurring! ;-)
I was thinking that if I really wanted to see what was going on, I would need to get these tubes and get someone to build a couple of oscillators and mixer for me to test - but the idea was not appealing - all the other stuff like PSU etc, and my limited space..
So I will spend my time in the virtual world - working my way through the theory.. first challenge is to understand the tubes well enough to construct some reliable models - then I can "test" the circuits on my laptop - if a real set of data comes along, the simulations can be compared against reality.
I really dont think there should be a huge problem generating the waveforms and mixer behaviour using modern electronics once I know whats really going on.. I believe I probably have a method of achieving the required end result in my hands at the moment - I have a working additive engine which allows harmonics to be mixed to produce any waveform - but its complex and expensive (each harmonic adds about £10 of actual component cost) and not disclosable at this time.. So I would be looking for simpler techniques.
Thanks Rob and Thierry - Your thoughts about whats going on at the tube are really helpful - And yes.. What you say makes sense.. my idea of the tube as a some sort of glass encased fet was a bit simplistic ;-)
