Jaycar MKII Problem- Test Voltage too high
Posted: 1/30/2013 12:13:13 AM
cupcakes6
Yes well you have to start somewhere with learning all this!! I only learned what diodes did this morning :)  To be honest I'm suprised I got as far as I did without encountering trouble being that I had zero previous electrical knowledge! I guess the ability to follow directions counts for a lot.
Most importantly, I think the multimeter at home is broken because I just borrowed one at work and got completely different (sensible) readings following exactly the same process I did at home! Even the reading from just the AC Adapter is drastically different.
And changing from AC to DC does make the rest of the post-diode readings sensible also.
I may be a poor trades(wo)man but I'm now confident that the tool was broken too! ;)
Thanks again and I'll keep you updated on if it works!
Posted: 1/30/2013 12:21:24 AM
cupcakes6
I agree I definitely need to do more reading! I tried to do a bit of research before starting but without something to be hands-on with, the concepts don't really make sense to me. Putting the kit together helped a lot and now the testing as well I am reading info that I can now understand a lot better.
