"Fred- so you you're saying that this interaction is caused by the loop (or wire running to it) being physically too close to a ground point , like a wire or trace, in the theremin circuit? Or did you mean externally, but nearby ( like a huge radiator or house plumbing)?" - Chobbs
The interaction is caused by ground at the theremin - As in, its circuit board mainly, and in the case of a metal theremin enclosure (which I am looking at using) the ground of this enclosure (and the enclosure will couple to the theremins ground - It needs to be actually connected for stability, but if it isnt it will still couple capacitively to the circuit). Other "local" ground sources include leads etc.
Again, as I labouriously detailed above, the effect will be more pronounced if the players other couplings to ground is poor..
The closeness of the loop to the theremins ground is not, in itself, the problem.. It is that when the players hand gets closer to the loop, it also couples more strongly to the theremins ground.. This results in the players capacitive coupling to ground increasing, and this increase is also seen by the pitch antenna..
If this is a problem, then moving the volume antennas operating point (or at least the distance at which the theremin is silent) further from the antenna, so that pitch change is silenced before it becomes bothersome, is the easy fix..
The other (best) fix is to ensure really good ground coupling to the player through other paths rather than directly (via changing hand capacitive coupling) to the theremin.. A conductive mat under the player, connected directly to the theremins ground, or an ECG pad... Greater and consistant player to ground coupling is the cure for many ills..
Alas though, not always easy - Easy in a studio, but move your theremin to some venue where there arent any pipes or cables under the floor, or for whatever reason grounding is poor, and your linear theremin can behave like a Gakken and your volume antenna affect the pitch...
Ok, most people wont notice! ;-) And I am probably being pedantic.. And perhaps real thereminists are automatically compensating for volume-pitch shif and dont even know that they are doing this.. But I do know it occurs.. And I think it occurs on every theremin to some degree, and can be noticable (and to me, annoying) if one sets the volume "null" point too close to the antenna -
I noticed it first when trying to learn to play the damn instrument - Trying to use the volume antenna.. I found that even trying to maintain a constant pitch while trying to master volume control was impossible - At first I thought I must be moving my pitch hand in "sympathy" with my volume hand, because the pitch always increased as I reduced the volume..
But I then found that moving the volume null point up by 20cm rather than having it set about 5cm from the volume antenna (I was nearly touching the antenna to silence it) got rid of the problem.. I actually prefered the null positioned close to the antenna though - It is (to me) easier to determine visually where the null point is when operated like this.
Having the loop (or volume rod) moved 30cm horizontally away from the theremin completely removes the "problem".. I have a capacitively "neutral" (actively shielded) lead between the theremin and the volume sensing section, so this neither reacts to the hand nor gives any ground effect.
I was still not able to usefully use the volume and pitch together - And have realised that my major problem, which pales all the others into utter insignificance, is that playing the pitch takes 110% of my, very personal computer's processing power - I am waiting for an implantable co-processor to appear (at an affordable price- Complete with an auxillary PSU to reduce circulatory load) before I will have any thought of attempting to master the theremin... And if the co-processor is any good, it will probably convince me not to waste any more time on this stupid instrument! ;-)
