Theremini is a "noise toy".
Just had a visit from a Moog Music rep here in my studio yesterday. While I'm ever so appreciative of Moog Music's effort to reach out to me in person, the three hours I spent working with the Theremini has turned up some serious issues with this device.
First, for those of us in the U.S. who get a theremini, you'll have to order a 3/8 to 5/8 stand adapter. Not a big deal, really.
The major issue with Theremini is that it's linearity is highly non-linear. It's progressively non-linear with notes nearest the rod being extremely closed together, and the lowest octave taking up half the room.
Even with quantization on, "I" was unable to play the Star Trek theme even remotely recognizably.
The device is not at all stable. Each time I attempted a simple arpeggio, I'd get half way through, and the device would mod-hop, and drift out of tune, up and down. I believe the instability is caused by the case being made of thin plastic, and the power cord not being properly grounded, even though the IEC portion of the power has a ground.
The appearance of the device says "CHEAP" to me. If I ever buy a Theremin, and only after the linearity problem is cracked, I fully intend to gut the device, and move it's circuitry into a proper wooden cabinet.
I don't like the fact you can't remove the volume loop. The small volume loop is easy to snag if you're trying to play staccatos.
The setup menu is a nightmare. A sight impaired user can not use this device, even with a magnifier, because the setup requires you to be able to see when the screen tells you to go on to the next phase of setup. I found it quite annoying to have the device howling during the setup of the pitch side. You can mute it with a cable over the volume loop fortunately, but you still have to unmute in order to hear what the device is doing. You have to stand four feet away at one point of setup, then you have to stand at arm's length, and then you have to hold your pitch hand near the rod to set the high end notes. The screen is so tiny, I was unable to setup, and calibrate the device. I had to have the rep do it.
The pitch rod is only about 14, to 15 inches long, which contributes to the serious non-linearity issue. Since I had the opportunity to have the theremini in my studio, I realized that the Theremini's rod is 3/8" in diameter, and just slips into the device. So, I grabbed the rod from my Etherwave Pro, and slipped it into the Theremini. The linearity was vastly improved, bringing Theremini from just being a noise tow, to at least being an entry-introductory theremin. The linearity was still not quite at a quality that a tune could be played reliably, however.
With the original rod in, there were only about five octaves, but only four could sort of be accessed. After the Etherwave pro's rod was in, we were able to get a little more than seven octaves with a range approaching that of an ESPE01 enhanced Etherwave. At that point the rep told me this would be the first issue Moog Music will address when he gets back to Moog Music. By the way, Theremini uses a solid aluminum rod. The Etherwave Pro's rod is hollow, and nearly 19 inches long.
Interestingly, the power supply brick has a heavy duty IEC cord running from the brick to the wall plug, but from the brick to the Theremini is a thin two wire cord which certainly won't hold up to too many uses.
The sound presets are pretty cool, and we had some fun playing around with them, but that quickly wore off.
I did notice the Theremini's quantization mode is easy enough to cancel. You just rotate the quantizing knob to right, and left quickly, and you're out of quantizing mode. All 32 presets could be used with continuous glissando.
I was disappointed there was only one theremin tone, and it sounded rather bland. I suggested there be at least half a dozen or more theremin tones to select from, and the rep seemed quite receptive to that.
When asked by the rep if I'd recommend the Theremini to my students, I had to respond with a resounding "NO".
I went on to specify that I would not even recommend the device to even the casual enthusiast because after a while, it's going to become readily apparent one will not be able to play the device musically at all in it's current condition.
You'll note I don't call Theremini an instrument. That's because it's not an instrument. It's an effects device at point. Nothing more.
