"I never look up every single word which I write. The English verb "to deceive" has the same roots as the French "décevoir". "Être déçu", literally translated "being deceived", means for me logically that you just did not get what you expected. There is neither dishonesty nor wronging implied." - Thierry
Fine -
Make that mistake ONCE, as you did to me on a post which caused me great anger, and which, after I had explained and understood your perspective, and we had agreed it was no more than a linguistic misunderstanding, and "patched up"..
But do it again, and its NOT an error - Its NOT a misunderstanding - Its DELIBERATE.
You KNEW exactly what you were implying when you posted the words "deeply decieved", because you made the same "mistake" before, and were corrected and advised of the offensive nature of what you said, from an english speakers perspective - And I now suspect that you knew it the other times you used this OFFENSIVE word, but used language as an excuse.
Dishonesty and "wronging" is not only "implied" it is ASSERTED when you use this word is used by English speakers.
We are being DECIEVED by you! - And I mean this from an English perspective!
But to hell with all the above - I am waiting for you to explain how a correctly built YAEWSBM can damage the oscillators.. Do that, and I will make an apology and leave TW permanently! - in fact, I would even be extremely interested in knowing how a faulty YAEWSBM can damage the oscillators if fitted with the 15pF isolation capacitors intact.. The only way I can see is if these capacitors were shorted and taken to a low-Z point like ground or supplies.... But your EPS01 would "blow up the oscillators" if you did the same with it!
