Hailing from the UK I am just starting my build of a Theremin based on the circuits contained in the article "Understanding, Customizing, and Hot-Rodding Your Etherwave Theremin" freely available from the Moog website. Like many before me the inductors are hard to source. For the fixed inductors I have chosen to use SMD devices as these seem readily available. I purchased the following from High Noon Investments Ltd., 9, Stirling Road, St. Leonards On Sea, East Sussex, TN38 9NW via Ebay.
Inductor 10mH 10% 0.18A SMD Part# Bourns SRR 1208-103KL 3off
Inductor 2.2mH 10% 0.4A SMD Part# Bourns SRR 1208-222KL 2off
Inductor 4.7mH 10% 0.28A SMD Part# Bourns SRR 1208-472LK (Fnl) 1 off
Inductor 1.5mH 20% 0.12A Smd Part# Bourns SRR 6603-152ML (Fnl) 1 off
This gives me the 10mH + 10mH + 10mH for the Pitch Antenna and 4.7mH + 2.2mH +2.2mH + 1.5mH for the Volume Antenna giving nominal values of 30mH and 10.6mH total respectively. I added the 1.5mH to bring me closer to 10mH total on nominal value but given the tolerances might not be needed.
Don't be afraid of the SMD moniker. Six of these items measure roughly 13mm x 13mm x 7mm and the smallest is roughly 3.5mm in diameter. I have mounted these "dead bug style" along each side of my prototype boards with hot glue.
For the variable inductors I ended up making a purchase from USA from seller Semisurplus on ebay the details of these are:
CADDELL BURNS 6740-33 47UH Subminiature Shielded Variable Inductors from CADDELL BURNS 6740-33 47uH Subminiature Shielded Variable Inductors
full specifications can be found at http://www.caddell-burns.com/PDF/A1042.pdf minimum Q is given as 55. I had the last three and it looks as though Caddell Burns have ceased production. However if you can get hold of them they seem on paper at least to be a good substitute for the Toko.
The fixed inductors came in at £9.03 whilst the Caddell's came in at just over £28 with shipping.
Obviously until I've got the circuits fully built and tested I have no idea how these components will fair, but i will keep you posted how the build goes.
