Hi all,
I've moved back to Australia from the US (where I got my Etherwave) and forgot to order a 220V power supply before I left. I know I can order one from the US (or Evilbay), but I'm pretty sure I can make one myself, which will be much quicker.
I saw that the schematic posted here: http://www.theremin.info/-/viewpub/tid/10/pid/58 has a regulator section in the circuit. The LM78L12 and LM79L12 should be able to handle about 35V, if I'm not mistaken. I can get a 17VAC adapter with an earthed output and connect it to the correct pins on a MIDI (5-pin DIN) connector.Here's a link to the AC adapter: http://www.jaycar.com.au/productView.asp?ID=MP3022&form=CAT2&SUBCATID=1000#12
Can anyone see any glaring flaws in my thinking?
Cheers, Pat
