Volume control: (if not technical, ignore the blue italic text )
Something I played with a little in the past, and quite liked at the time, I am going to test again and perhaps include -
Normal theremin operation is that the volume gets softer as the hand approaches the loop - I find this difficult (and the reverse equally difficult) - one is controlling volume as a function of position - I am (with hand drums and velocity sensitive keyboards) much more in tune with controlling volume as a function of velocity - to me its just a lot more natural.
Taking the voltage from the volume 'antenna' circuit, and passing this into a 'change' detector (HPF) so that the faster the signal changes, the higher the output voltage / volume, one gets a velocity / volume relationship - feeding this voltage into a RC lowpass with a TC of perhaps 5ms (or perhaps adjustable, say 1ms to 25ms.. its not pitch latency), one could sustain an output by continuously moving the volume hand - perhaps similar to the behavior of Bowed string instruments. where the sound is only produced while the bow is moving.
I can see that for sustained notes, the above might be a pain - but for short or staccato notes, one could play the note by moving the hand towards the loop, and the following note by moving the hand away from the loop - so one could effectively beat ones hand in time to the music, and control each notes loudness by the speed of that movement, and have a single switch on the theremin to select between this 'delta mode' and normal operation.
What I DON'T know, is whether such a scheme would actually be playable - whether the arm movements would interfere with the players ability to maintain pitch... But seeing some thereminists (one at least ;-) managing to do great fret-less bass simulations on a theremin, I think it may be possible - and it may also make cello / violin 'emulation' more natural.
Again, although not strictly framed as a question, I would really love to hear thoughts on the above from any musician / thereminist ;-)
