Hello,
I have a fairly new Etherwave Plus (no modifications) and I am noticing some interesting sounds coming from the headphones output (I use headphones exclusively, no amp yet). It is plugged into a grounded circuit and well any from any surrounding electrical or metal objects.
1) When holding my hand at zero-beat I can hear some quiet static/crackly noise. As I start to move my had toward the pitch antenna and before any sound is produced (as a reach the edge of zero-beat) the static noise completely disappears and everything is dead silent. Is this normal or anything to be concerned about? I'm wondering if I'm picking up any ambient RF-type noise possibly?
2) If I should rest my hand on the volume loop and then lift it I can hear a soft "pop" or "buzz" noise that is very brief. If I drum my fingers on the volume loop (gently) I can get a series of these same noises. Again, is this indicate any electrical problem?
Neither of these two conditions is particularly annoying but I have nothing to compare this behavior to so if anyone can let me know if this should be cause for concern I would greatly appreciate it.
p.s. - I'm awaiting the arrival of my ESPE01 module and want to make sure my Etherwave doesn't have any electrical defects before installing it.
Thanks in advance for any comments.
