Etherwave Assembling Kit Manual Unclear, need help
Posted: 5/1/2016 1:02:55 AM
xtheremin8
hey dom,
the volume knob is not a volume knob as it is on a amp or so. it's to set how high you have to lift the volume arm to get the full volume.
double and triple check your soldering. i followed these instructions : etherwave tuning. wich brings the unit into a playable state. not perfect, but playable. for ultimate fine tuning: go to colmar for the summer academy and meet thierry. he tames every whacked theremin.
do you live near my place?
@christopher: it's walpurgisnacht!!
Posted: 5/1/2016 7:46:59 PM
Normally, the main PCB comes well pre-adjusted, thus, even without touching at the variable inductors, you should get a playable instrument, perhaps not with optimal linearity and pitch range, and perhaps with non-ideal volume response. But it should work.
Before fumbling around with the tuning, one should check with a multimeter (the black probe always at the green ground wire) :
Black wire : -11.3V
Orange wire: +12V
Brown wire: 0 - +12V depending on the Brightness setting
Red wire: 0 - -11.3V depending on the Waveform setting
Blue wire: 0 - -11.3V depending on the Pitch setting
Violet wire: 0 - -11.3V depending on the Volume setting
Posted: 5/2/2016 6:55:48 PM
xtheremin8
thanks thierry. 👍
