Music stand
Posted: 10/2/2016 6:20:50 PM
jocala
I can play by ear, but I prefer to read music. What music stand solutions are suitable for the EWS theremin?
Posted: 10/3/2016 8:13:10 AM
Valery
For EWS you need to find for him a MIC stand, if you need a music stand, any good, but it is necessary to adjust the Theremin to work correctly in these conditions. To MIC stand easier to transport I cut it down to size. Very convenient.
Posted: 10/3/2016 5:38:56 PM
jocala
"For EWS you need to find for him a MIC stand, if you need a music stand, any good, but it is necessary to adjust the Theremin to work correctly in these conditions. To MIC stand easier to transport I cut it down to size. Very convenient."
I've had zero luck front-panel tuning my EWS with a metal music stand close-by. Zero beat is nowhere to be found. Move the music stand away and all is fine.
Posted: 10/3/2016 5:46:49 PM
Valery
Oh yeah, it happens all the time. You should try to place the theremin is not less than 2 meters from other items...
Posted: 10/3/2016 5:56:51 PM
jocala
"Oh yeah, it happens all the time. You should try to place the theremin is not less than 2 meters from other items..."
 Yes, that's my issue. 2 meters is way too far for me to see the music. So let me rephrase:
Are music stands available that cause minimal to no interference with the theremin?  Would a stand made of wood or plastic work?
Posted: 10/3/2016 6:11:16 PM
Valery
Yes, of course! if a music stand is not made of metal, the impact on the theremin he will not have. And to adjust in a GROUP where all are very close could use a telescopic PITCH antenna. It can be trying to raise or shorten when the regulator front- panel does not operate.
Posted: 10/3/2016 6:38:52 PM
jocala
https://www.amazon.com/Stageline-MS40OK-Music-Stand/dp/B001L8MDFA/ref=sr_1_5?s=musical-instruments&ie=UTF8&qid=1475519679&sr=1-5&keywords=wood+music+stands
So, something like this Stageline wooden stand could sit in very close proximity to the EWS without problems?
Posted: 10/3/2016 7:01:14 PM
Valery
it all depends on the number of nails and screws in construction. I think this stand is too bulky and expensive. I would make yourself out of wooden slats or plastic, and the lower part (the tripod) can be made of metal.
Posted: 10/3/2016 7:03:35 PM
jocala
Thanks for your feedback.
Posted: 10/12/2016 8:10:55 PM
jocala
theremin
Here's what I've ended up with. I seem to be able to tune around it, it's fine for individual scores, ok with books, depending on size.
Available at Amazon: https://goo.gl/ohOUpx
