Played a bit with this oscillator on breadboard.
LTSpice simulation is far from reality. To get it working on breadboard, most of part nominals must be changed. And voltage is lower than predicted by simulation. Many part combinations stop oscillating.
Lowest padding C which was working for me on breadboard was about 33pF.
It seems like Darlington very useful in this oscillator. Cannot get it working with single transistor.
"The ~1pF delta C from the hand will be rather swamped by the 110pF, so you're lowering SNR by a factor of 100 (40dB) right there (in terms of oscillator noise). This magnifies any temperature / voltage drift issues with the variable and reference oscillators as well.
My unsolicited advice is to find or develop an oscillator topology that minimizes antenna capacitive padding. Capacitive padding is usually required to provide a low impedance to a series EQ coil, but if there is no EQ coil then you should be pursuing high impedance at resonance. Too many designs seemingly remove the EQ coil but don't remove the C padding along with it.
The problem with having an EQ coil is you have three things that have to be tuned or pulled into alignment:
1. EQ L and antenna / hand C
2. Variable oscillator LC
3. Fixed oscillator LC
You can align 3 by generating the fixed frequency digitally, but you will need some manual control to align 1 & 2 with each other. Even if you don't heterodyne 1 & 2 will still need some form of manual alignment. FredM struggled with this for years. My solution is to do linearization numerically downstream, rather than in the oscillator, and this is the standard solution these days for many types of problems. The trick is to pick a method that is amenable to digital I/O, and to process it in a way that inherently gives decent linearity. Any "touch up" after that will be much less drastic. Taking an analog Theremin and somehow digitizing the output isn't the best nor easiest way to go."
Probably you are right. Measuring oscillator frequency directly would help to avoid a lot of troubles with heterodinings.
It was first schema which I tried. But dropped it once got about 1000 different measurement steps per hand distance range.
Now I'm trying to design oscillator giving max delta frequency for Cant capacitance change.
Currently playing with LTSpice model based on Triple Darlington with pulldown resistors.
Simulation with zero antenna padding cap is working. Changing antenna capacity from 6pF to 8pF changes freq by 10 percent.
In my 60MHz based frequency counter it may see 6000 different positions (if averaged in 1ms interval). Probably with additional averaging it may be accurate enough even for linearization at far hand distances.
Tomorrow I'm going to try it live on breadboard.
BTW, what is pitch antenna capacity for hand far (1meter) and near (10cm)?
Can antenna padding C be really 0? A'm no sure that antenna with 6pF capacity will behave in the same way as equivalent cap connected between L and ground. W/o padding cap overall schematics looks like coils staring at the air. :)
