Boom Arm
Posted: 1/24/2018 2:53:23 AM
bspiglejr
Has anybody tried using a suspension boom arm for a theremin?  I want to mount mine in the office, but be able to retract it into a shelf when I am not using it.  It looks like most (or all) of the microphone suspension boom arms would not be able to handle the weight, but maybe a monitor one could be adapted?  I have a Moog Etherwave Plus with the microphone stand mount on the bottom.
Posted: 1/24/2018 8:33:57 PM
rupertchappelle
Nope. Search on:
Scissor Arm, Scissor Arm extender, Extension Arm, would work, it it was sturdy enough, but you would've to mount it to a wall.
Camera crane jib - can hold a camera so it would work.
Monitor extension arm - probably what you want.
At lot easier to mount it on a mic stand and simply pick it up and move it, or swivel your chair. Less problem for whoever you work for.
Also, use a lighter theremin.
It's bad enough that the player is moving, but the theremin moving as well, gives you auto-vibrato, probably at a frequency you will not like.
