Fascinating stuff Art, thanks for sharing!
"Note that the 302 theremin design implicitly avoids any volume-control latency that would be humanly detectable." - Art Harrison
Yes, latency isn't just for digital Theremins!
"Adjustment of the Volume Zero control will allow a wide range of volume response, both for staccato and legato phrasing. The curvature of volume response is a little closer to distance-linear for voltage, as opposed to distance-linear for decibels. That was a conscious design decision in order to make the volume control voltage output more useful for driving external devices like VCFs, etc."
It's my belief as well that the volume field shouldn't be perfectly linear.
"Note, also, that a factory mod is available to switch the "closer for louder" response to "closer for further." However, I generally advocate the "closer for louder" response, because it is somewhat easier to learn."
I personally agree with this.
"The subject 302, incidentally, seems to be one of the relatively-few we built for left-hand players. In the next production run, we'll probably put a volume-response option switch inside the case. Violinists are one group of players that like left-handed theremins, even if their left hand isn't dominant, because the violin is generally fingered with the left hand."
Interesting.
Art, I have no direct experience with the 302, but have you considered perhaps spacing the plates farther apart and enlarging the fields?
