Hi,
I'm new to owning a theremin and I have recently been confronted with a conflict. I've owned my theremin for 3 months now and one month I had it set up on a shelf as I was occupied with other things. My theremin was working properly before I had set it up on the shelf. I had no problems tuning it. However, I just set it up for use again only to find I'm having problems with, what I assume is, the pitch antenna.
The problem is that I can no longer tune it. I can not reach a zero beat zone as if I stand away from my theremin it remains activated. Nothing has changed in my home apart from setting up my computer that has a wireless wifi antenna. I unplugged this and this made no difference. I have removed the pitch antenna from the theremin while on to test to see what happens... Still remains activated.
When I had left it on a shelf I left both my volume and pitch antenna screwed in (finger tight as the manual said).
It's mounted on a microphone stand and I just bought a new audio/visual extension cord to see if what I was using to plug it into was the problem... This changed nothing.
I've read on other forums about the top needing to be removed and things fiddled with. This is out of my realm and is something I most definitely cannot do myself. The suggestion to do that also seemed to come from topics where people built the kit themselves. My theremin came preassembled.
I am at loss on what to do and at what has happened.
(I did leave my aux cord adapter in the theremin it of fear of misplacing it. My headphones only display on one ear if it is pushed in all the way which never happened before. I have to slightly pull it out now for both sides of the headphones to play... Was leaving that plugged in there a possible culprit?)
