"Seeing the video of the lower frequency hump moving helped a lot (initially didnt realize it was a video until I went back and read the post a bit better). Its a lot more dramatic than I had initially thought considering I cant hear it very well (though seeing the hump did help my ears catch it a bit better." - Mennenth
Using your eyes to direct your ears is a powerful thing. Though it can misdirect as well (e.g. Foley "artists" in film).
"I'm still not entirely convinced the Claravox is at fault because I dont trust youtube though. Digital aliasing is affected by a lot. Volume, vibrato, sample rate, etc, and youtube could be messing with the audio poorly."
I know what you mean. I have a fairly popular Logitech webcam, and the Windows audio driver sets the maximum sample rate at 30kHz, so I can't use it to record anything much beyond a sine wave without it aliasing all over the place. Had high hopes for it re. Theremin videos. Operating system audio paths are always a hot mess.
"It could one of those things where it technically happens, but at an imperceptibly low level (dewster found Bendra's samples to be clean) and the issue is just getting amplified when the audio gets passed to youtube. Though if people are hearing it in person with a theremin hooked directly up to an amp or pa system or whatever then thats another story. However ContraDude says he can't hear it in person on his..."
With the volume modulation of frequency going on, my money would be on it actually happening in the Claravox. But it maybe only happens when you hit on some special combination of pitch and volume and local oscillator frequencies, causing a secondary pitch heterodyne from the volume oscillator? I dunno. Analog Theremin designers would have better intuition here.
"I wonder how the spectra graph looks if one controls the Claravox through midi instead of trying to play it..."
I would guess MIDI in can only control the Modern mode synth? If so, I can't imagine how there would be a traveling hump in that. Then again, the Cvox hardware and software seem to be somewhat half-baked.
[EDIT] More Claravox humping video: [MP4]
