Yes, this happens every time I let the computer go to sleep while connected to the theremin. Dismiss thi dialog and go to gear icon->information, will show you if you are on the latest firmwareIt says I am at 1.0.1 and the update is 1.0.2.I am using an Ipad and I only have it connected to the Claravox when I want to use the editor. It is also hard to ignore, as I use the editor a window keeps popping up telling me to update.I opened a chat with Moog, and the message was that they are busy and will email me… I then received a form email saying they will get back to me sometime …@bendra, were you ever able to update? Is everyone else on 1.0.2?
Update on this. I connected with Jared at Moog and had a very good volley of emails, back and forth. I am quite satisfied with the customer service. He concluded that because the section of the Information menu called “Instrument Information” was greyed out, it means that my Cvox is using the most up to date firmware. The glitch in the software is that it is not recognizing that and hence the update window keeps appearing. Nothing to be done about that besides ignoring it, is the conclusion.
I was also having a problem with atonal underlying harmonics intermittently happening, making the instrument unplayable, which Jared was trying to work out with me. Tried moving the amp, moving the theremin, changing cords, using headphone only with no amp in the room etc. etc. when I finally (accidentally) realized that the Cvox was reacting to my iPad’s power cord! Even without the iPad attached to the coed. Just the presence of the cord within 5-6ft. of the theremin was causing the distortion. Luckily, the fix is simply to use the iPad in battery mode. My Claravox is working great now, I am very pleased with it.
