MOOG ANSWER !
Hi Andre,
Suffice to say, the Claravox is going to behave differently from the average Theremin. You are correct that normally there would be no sound present when placing a hand near the volume antenna. Due to the specific design of the Claravox, some latent signal can come through when using Traditional Mode. This behavior is unrelated to the issue alluded to on early models.
There are some ways to mitigate the presence of the latent signal, however there is no one way to eliminate it completely, so there is a chance it will be heard depending on several factors. The first thing we recommend is to perform the calibrations listed in the back of the manual starting on page 63. After performing said calibrations, we then recommend following the instructions on page 20 under "Tuning the Volume Antenna." The last portion of that instruction is important for mitigating the latent signal.
If the latent signal is still coming through, you can make some manual adjustments via the trimmer in the small hole located below the volume antenna. You will need to go slow and make very small adjustments by ear until the signal is reduced with your hand near the antenna. Note that by making the adjustments, you may need to alter the panel settings to dial in the desired volume control. It might take some back and forth to get it just right.
Best,
Z Briggs
Service Administrator
Moog Music
To me, a simple summery of this answer is :
"Hey, a theremin is supposed to make music. Why do you want to silence it ?"
I could answer with the famous sentence : the silence after Mozart is still Mozart. But how can I play the silence after Mozart ?
Now, imagine I have a problem with my car. Even if I stand on the brake, I can't stop it. It continues to run very slowly.
MOOG MOTOR answer :
"Suffice to say, this car is going to behave differently from the average car. You are correct that normally it should stop completely when you press the brake pedal. Due to the specific design of this car, some latent speed may remain when driving in Traditional Mode.
I suggest that you park your car on a large enough and flat area and carefully adjust the steering wheel so that it will continuously run in circles. By adjusting the trimmer behind the little hole on the dashboard, you should be able to reduce the speed enough to allow you to safely leave the car.
Best !"
As we say in french : "Circulez, y'a rien à voir" !
