Claravox Stand "Set Screw" broken by design?
Posted: 3/17/2023 3:08:31 PM
Yngvox Moogsteen
I think the stand should have come with the Claravox.  I think it should also have a shorter low point.  I like my Theremin low with volume antenna about mid hip.  I have it adjusted all the way down and it is barely low enough.  We aren’t all as tall as Gregoire Blanc.
A question to other Claravox owners.  My Claravox antennae’s both don’t lock in place but just sort of rest in place.  They have always seemed fine in operation but I have always wondered if this is typical.
Thanks
Posted: 9/8/2023 3:43:08 PM
André
What happened to Simon's pictures in this topic ?
Yngvox Moogsteen, I agree with you. The stand is too high.
I'm 6' tall (1m83) and I have to set it almost at the lowest possible position.
Which makes it difficult to untight the knobs when you want to remove the Claravox from its stand.
Those knobs are too small anyway, and they should have a different shape, easier to grasp, like these ones :
https://www.amazon.fr/Filetage-Photographique-Plastique-FLEX-ARM-PM1413/dp/B08X7J5R8R
You can always trim (saw) the end of the legs (1 or 2 inches) and take the opportunity to replace those slipping plastic feet by soft rubber feet.
