[b]**** Lucy .. This topic is now closed, so if you need to communicate here, edit your last posting !!
Have sent you an email.. Kit should be ready to send early next week. I NOW HAVE THE DETAILS ON WHERE TO SEND IT.
When you have it working, you can either send me a cheque, or make an on-line donation of >= £40 to [/b]www.streetkidsrescue.org. [b]I will be sending you the EPE article which details all construction and testing, and also has details of antenna parts / construction.. alternatively you can construct experimental antennas using plastic tube and alu foil tape, and use these as a template for 'real' antennas .
I will be here to advise you through the build / testing process... If this proves troublesome, we can open a new thread in the construction forum so that others here can join in.
If for any reason you are not happy with the Theremin, you can return the kit to me and make no payment or donation. If you need to contact me directly, [/b]http://www.fundamental-designs.com/[b] has my address, phone number etc.[/b]
