Thank you for your nice comments, Gordon.
The video was taken a few days before I played a live gig at a large private party in Kansas City. How many people were there? I don't know however they served over 300 pounds of BBQ!
This post concerns a topic near and dear to Thereminists: pitch fishing. The techniques below are useful whether or not you use a pitch-preview.
[i]You will likely find this an easier read if you move your pitch hand along with the examples. Enjoy![/i]
[b]fishing conditions[/b]
There are four primary issues involved with pitch fishing: 1) time, 2) finding the target note, 3) the beat, and 4) the length of the target note.
The easiest situation is: a long span of time to find the pitch, music that includes the target pitch, an entrance on beat 1 of a measure, and a target pitch that is a long note.
The toughest situation is the reverse: little time to find the pitch, music that is not harmonically related to the target pitch, an entrance on the "and" of a beat (that is, an entrance on, for example, beat 1 1/2), and a target pitch that is rapidly followed by other pitches (i.e. a scale or jump).
Let's look at each situation seperately, then consider them as a whole.
[b]Time[/b]
When there is a long break in the Theremin part, you can actually relax your pitch arm and take a luxurious amount of time to find your starting pitch (up to 30 seconds). In this situation, you don't have set your pitch hand near the note at all -- rather, you just raise up your pitch hand and commence a leisurely fishing expedition. There is plenty of time to find the note.
A shorter time may mean that you will first raise your pitch hand close (according to your best guess) and quickly position it to the starting pitch.
If there is little time you will actually have to practice the jump from the previous pitch and hit your target close enough that you can make a quick correction.
The point of this is that, with less time, you have to get your pitch hand closer to the target pitch so you don't run out of fishing time.
[b]finding the target note[/b]
If while you are fishing, the musical accompianment contains your target note, you simply match your pitch to that note and bring up the volume when the time comes to play the note.
If the accompianment contains your note, but in a different octave you will likely find it pretty easy to tune your target note.
If the accompianment doesn't contain your note but is harmonically related to your note, you will probably be able to find it. An example would be where your target note is the "e" of an a-minor chord. The accompaniament may only be sounding "a" and "c" yet you can, with a little practice, easily nail the "e". This is incrementally more difficult than matching the pitch directly.
[i]For me personally, the "harmonically-related but doesn't contain the target pitch" is the most desireable situation. Since the Theremin's target pitch is not doubled there is a little more "give" with the tuning.[/i]
The toughest situation is where your target pitch comes in at the same time the chord changes! That is, during your fishing time an e-minor chord is playing and then you must play "c" along with an a-minor chord. How do you find "c" while an e-minor chord is sounding?
Your aerial fingering can come to the rescue here. For instance, say you wish to play the "c" in first position. Well, go ahead and fish for the "e" above the "c" in third position. Nail the "e" and simply move to first position as you bring the note up. By fishing for "e" in third position, you can nail "c" in first position. Of course, if you need to hit "c" in fourth position, you can fish for the "b" below in third position or for the "g" below in first position.
You can see, that by fishing for either "g", "b", or "e" you can hit "c" in any position you desire!
[b]Time[/b]
