The natural non-linearity (the result if inverse square capacitance / distance relationship) is for notes to be compressed close to the antenna (high frequency) and stretch as distance increases..
Methods are employed to correct this non-linearity (most often by having an equalising coil in series with the antenna). Non-linearity at the low frequency end (particularly when distance between intervals get smaller as the audio frequency gets lower) is the result of balancing or tuning the equalization circuit incorrectly. Getting the balance between good linearity at the mid -> high frequencies, and maintaining good linearity in the low -> mid frequencies is one of the biggest challenges when designing or setting up a Theremin.
I believe (but may be wrong here) that the E-Pro linearity is achieved by careful positioning of the equalizing coils above deliberate capacitive pads on the circuit board.. the wire ended equalizing inductors can be moved manually to an optimum position (both vertically and horizontally) for fine tuning with the antenna.. I suspect that Moog have a jig of some kind which they use to optimally align these inductors during the assembly / testing phase..
But the above is only a guess based on some photos I have seen of the boards.
Fred Mundell
Fundamental Designs Ltd.
Electronics Consultant.
<- See Profile Image for Email.
Designer of Theremins and other alternative electronic music controllers and instruments.
