[i]<< "I think you missed my point. Not "different pitches have different timbres" but "while the pitch is changing the waveform gets distorted." - GordonC >> [/i]
Not sure I absolutely get what you are saying here..
With (almost) every method of changing timbre as a function of pitch (morphing / VCF / PWM) the statement "while the pitch is changing the waveform gets distorted." is, I think, true - This happens to every cycle of the audio (certainly with analogue VC modules where there is no stepping).
One thing bothers me a bit - I am sure some mathematician would answer this and have a laugh - Take a pure sine wave, and sweep its frequency in an analogue way, so that the frequency change is occurring (albeit fractionally) during each cycle.. Lets just look at a crude example.. first 1/4 cycle has a period of 1ms, 2nd 1/4 cycle has period = 1.001ms, 3rd = 1.002ms, 4th (final) = 1.003ms... This sine wave is, by definition, being distorted by merit of its frequency changing - the shape of a complete cycle is not a pure sine(!?)..
Am I correct in believing that the degree of distortion 'imposed' upon any waveform as a function of frequency change, is proportional to the rate of that change?
Also.. Taking the sine example.. this is (when frequency is constant) without any higher frequency harmonics.. But with a complex waveform, this effect will act on each harmonic, to a lesser degree the higher the harmonic.. one would? (I wonder) get maximum distortion on the fundamental (which will produce resulting harmonics while pitch is changing) and the effect will be most noticable at lower frequency (frequency change vs waveform period)..
All without any extra processing.... But probably quite miniscule - perhaps even unnoticable... impossible to observe at audio frequencies with my equipment.. and I dont know if I can hear it.. Changing pitch does sound 'brighter' - but is this due to some other neurological function rather than hearing extra harmonics?
[i](these thoughs were inspired by some experiments I did recently.. I bought two wonderful old HP signal generators with 1Hz resolution, from 1Hz to 20MHz, extremely pure sine, and precise sweeping - I am using these to calibrate my Theremin circuits.. I can feed these generators directly into the heterodyning stage.. Anyway - I ran a (fast) sweep checking the waveforms on my analyser, and noticed a small distortion.. My analyser is not brilliant, signal below about -75db gets lost.. so I was surprised to see any distortion. When I stopped the sweep, there was no distortion (that I could see), when I slowed down the sweep, the distortion dropped out of view... which got me thinking 'bout all this again)[/i]
