(This answer copied from another Theremax thread)
The volume antenna affected the pitch depending on the setting on coil L4.
This procedure worked for me:
After tuning the pitch oscillators, before you remove the VCA jumper, go ahead and turn the adjustment on L4 and you may find a place where L4 interacts with the pitch oscillator. Adjust L4 to a position where the pitch is stable as you move your hand to and from the volume antenna. Then, remove the jumper and tune L3 to achieve your desired volume response.
Also, might be worth your while to go to Forums/Theremin Construction/Theremax ... The problem you are describing has happenned to others and I have been able to reproduce the problem on mine. Also, PAIA's website has some troubleshooting info (written by Scott) that discusses this issue. Hang in there -- the Theremax is not the easiest kit to build however most problems are due to the tuning of the coils, damage to the coils from overheating during soldering, cold/weak solder joints, and improperly polarized components.
So get out your schematic, your magnifying glass, and hang in there. The Theremax has a clear tone and you will enjoy it once you get it working.
