The only implementation of a volts-per-octave oscillator (that I know of) is to implement a linear-to-exponential converter.
Jeff once sent me a picture of his tannerin. It does not use a ribbon controller -- instead, it has a roller that connects to what appears to be a telescoping antenna -- as such I think the linear movement of the roller causes an exponential change in the length of the telescoping rod/antenna within the tannerin's case. Perhaps Jeff could jump into this thread -- I've only seen pictures, haven't seen the schematics.
Anyway, since the frequency doubles with each upward octave, you would need some means to convert linear motion on your ribbon controller to exponential changes in the frequency.
