Hello,
I've just recently bought a Moog Etherwave theremin kit and eagerly but carefully followed the instructions to assemble it. However, when I turn it on a high single note is heard which doesn't change with location or any movement around the pitch antenna (although touching the antenna does create very small changes). The volume antenna can be used to vary the volume of this single note, although the note can be heard if no-one is standing near the device and silenced only when a hand is placed inside the antenna loop. Adjusting the pitch control varies the pitch of the note along a range but as the note appears to be created without anything being near the antenna I cannot find a 'zero point'.
If anyone has any suggestions as to what my problem could be and/or solutions I would be most grateful.
Thank you.
Thank you.
