[i]Would switching the 5mH and 2.5mH totally mess up the volume controls? [/i]
I don't know. You have to try it. I would
be surprised if it *totally* messed it up.
[i]I interpreted the 5mH as being bigger; is that correct?[/i]
If the inductors are built using the same
core than the 5mH inductor requires apx 40%
more turns. The inductance is proportional
to the square of the number of turns. To get
twice the inductance requires sqrt(2) * number
of turns.
[i]I've been trying to tune the pitch, and when my hand touches the antenna, it jumps to a very high "ping" like note. I've tried to change this, but it seems like changing it sacrifices sensitivity of pitch. What should I do?[/i]
Don't touch the antenna ;-) Without seeing
the board layout it is hard to say. Is your board
layout similar the board in the EM article?
Is there other metal near the oscillator?
How did you layout your coils? The EM article
recommended a specific spacing *and* orientation.
To determine the orientation you need to look
at the direction of the coil winding ( I am
not sure if the coil is marked).
(* jcl *)
of turns.
(* jcl *)
