Are you using the telescopic aerial as the pitch control? Unless you have it exactly the same length every time, you will have trouble tuning it.
As you've got past the first stage and got it making sound, the next step is to put it into a bigger case with a fixed length pitch control rod. This makes all the difference to these kits and is the best first mod to do.
Then, you can look at which of Maxies mods you want to do.
But, really, put it into a bigger case with new rods first as this gives you a constant to work with and makes things so much easier.
Any problems, please post back.
MarkT
