You might need to strip the insulation off the end you are holding if you want to just wind some wire around an old drumstick. That would create better coupling between you and the theremin's antenna, even though you are not directly touching the theremin antenna.
Ideally you are going to want the theremins to be less sensitive, so that they respond only when you come close to their pitch antennas.
Since this would create yet another tuned circuit in the mix, you might experiment with different numbers of turns of wire on the drumstick ... different number-of-turns should produce slightly different pitch, if things are setup right.
Not sure what "minimum theremin" design you are using. If you build ones that make use of CMOS gates, they may not work well at all for your idea.
Don
Don
