[i]>>"A 7809 may be replaced by a 7808 with a 1N4001 diode between ground pin and ground, which gives you a virtual 7808.7"[/i]
I cannot see any particular reason why the circuit should not work with 8V.. if 7808's are available easily in the USA, I would try this... I am a little worried about the diode Vf elevation of a 7808 to 8.7V - Vf is strongly dependent on If and temperature, so this may cause thermal stability problems (If will be inversely proportional to current demand on the regulator, and proportional to incoming supply voltage and any fluctuations thereof)
[i]">>For me it seems perhaps not to be a bug, but a feature... why shouldn't I jump into the "Kees breach" and make some good AND affordable theremins based on this kit in order to bring happiness into the theremin universe and some strongly needed money in mine?"[/i]
Why not indeed! - My comments regarding this Theremin were purely from a perspective of newcomers who lacked knowledge to (a) Realise that their Theremin was more difficult to play than it should be (b) lacked knowledge / skills required to correct the problems.I do, however, have reservations about other aspects of the design - in particular the use of the the MC1496 bias as a gain control, and the implementation of the 'voice' control.. I suspect there will be some adverse results, particularly from the bias.
If you took the kit, and with knowledge of both the playing and technical aspects, produce a real musical instrument, then you will certainly be doing everyone a service!
[i]MarkT: "With pitch AND volume all in a self build kit form, which I will also point out contain EVERYTHING you need to get going, even solder. There is no need to nip out to Maplin (or wherever) to purchase additional components because it wasn’t included, its all there."[/i]
This may have been true for past versions - With this version, in order to get a playable Theremin, I believe one would at least need to "to nip out to Maplin" to buy a tuning potentiometer, coil core, and ECW... THIS Theremin is a LEMON! - I am not detracting from its predecessors in any way.. I am simply stating that this particular mutation is rubbish... Kees could not have used THIS design for the Theremin he produced.
