When plugged in and turned on, the theremin has a tone. The volume antenna does work, and the knobs seem to work, but the most important problem is the pitch antenna.
The pitch doesn't change no matter what I do with my right hand, touching the pitch antenna or not. I even walked away from the thing and nothing changes. I checked the connections and everything seems right.
Not sure if this is an common problem, but I can definitely take a picture or two if that helps. I really appreciate any assistance, it is really exciting at least that the thing turned on and is making a tone.
Can't wait to play! Thank you!
-Chris
