oops.. got the threads muddled..
Due to site being down some postings seem to have got lost - this should be on the 'blasphemy' thread..
This is a reply to postings here (http://www.thereminworld.com/forum.asp?cmd=p&T=4138&F=3) and the above:
[i]"Regarding your edit about speakers from the Thirties, I agree fully. I've been chasing better tone through single 8" or 12" speakers lately...
Could a combination of box with sine wave mixing and a speaker with an adjustable high end allow a wider range of tones or would that be redundent, achieving the same end through two different means? ..
I find if I run my Etherwave through my full range speakers with tweeters it sounds horrible. Way too much buzz in the high end. But run through a good single 8" or 12", mostly full range speaker, the sound is much better. So far I've only tried a few Eminence and a few Jensens. The Jensens are MUCH better... " - Dae23 [/i]
The first thing I want to say is this.. From the many emails I have had since my recent comments, a clear fact has emerged - There are those who love the EW tone as it is, played through modern equipment, and Hi-Fi speakers..
There are those who strongly dislike the EW tone played through modern equipment, and Hi-Fi speakers.. Even with the waveform set to its most mellow..
The majority neither particularly like or dislike the tone - They rightly proclaim that without The EW there would probably be no viable low cost Theremins available today - That without having brought this Theremin onto the market, other manafacturers would probably never have thought about producing Theremins, and Theremins would never have become so popular and available at reasonable cost.. These people declare that "Without the Moog EW Standard I would never have played a Theremin" - And I think they are right!
Anything I have said, and anything I say, must be with the above kept clearly in mind - The EW is THE Theremin "of the people" - It is the first instrument which TRULY brought Lev's dream of an affordable instrument, into reality.. Without Bob Moog's efforts in this field, I highly doubt that we would be chatting on TW.
I believe that, even if one was to emulate a RCA output waveform perfectly with another design, it will NOT sound the same as an RCA did in the 30's.. and that to get the same "RCA" sound through modern amplifiers / speakers, one would need to design an instrument with output harmonics which are MUCH lower than the harmonics seen on the output waveform of an RCA.
To do the job as precisely as possible, one would need to get a complete original RCA setup (amp, speakers etc) and analyse the sound coming from this, and then produce an instrument to match this sound when played through a modern system.
The above is NOT what I am trying to do with this 'box' idea.. The 'box' is simply a way to achieve mellower (more sinelike) tones from a slightly modified (one connector added) EW Standard, for those who prefer a mellower tone - The original EW tone in this latest version of the idea would remain unaffected.
[i]"Could a combination of box with sine wave mixing and a speaker with an adjustable high end allow a wider range of tones or would that be redundent, achieving the same end through two different means? .." - dae32 [/i]
The basic idea of the box is the attenuation of high(er) frequency harmonics - And there are many ways of doing this.. including modification of speakers etc..
None of this is simple.. Design of speakers / cabinets and the effect of resonant ports, posiotion of the speaker from the wall, size of room, nature of furniture etc all affect the eventual shape of the 'sonic spectrum' - So yes, changing the speakers and amplifier responses WILL change what you hear..
The main effects will be heard at the high frequency end - (and if the speaker cannot handle bass, at the low freq
